Solved SSL Connection problem
ENPL
Lately, after app update on iOS I get "Cannot establish SSL connection" and cannot change status nor register account by scanning QR code. The same on 2 iphones. I've updated 3cx system on server and have not any problems on Android phones.
Is there any solution of this problem?
Thanks in advance
Reactions: enamchuk
Can you share the exact error?
3CX v18 Debian 10.
I had the same problem.
I renewed the SSL certificate, after which I began to receive a new error when scanning the QR - error 404.
The Android application works perfectly with this QR.
The previous version of the application (before February 27) works fine (no complaints yet)
Thanks in advance
Sounds like you have the same issue with no system data from the server in the new version of the iOS app as reported by other posts here in the last few days since the new v20.0.1.x dropped. The new version of the app requires a valid SSL connection to the server now, unlike the previous versions. See the other posts for more info and examples.
Reactions: TheodorosG_3CX
SSL Error occured. Cannot establish connection with server
serwer linux Debian 12
Version 20.0 Update 0 (Build 1620 Release)
certificate is valid for eastnews.3cx.pl
No problems at Android app
Reactions: enamchuk
the new 3cx app has problems.
The problem is the app.
It works with the old app.
Tell me something that I don't know...
Reactions: Roberto.Fasola
My employees require the app to work on their iPhones, but I don't know what needs to be fixed?I can't even configure this shit manually.
The app is defective.
A new update is needed.
Reactions: enamchuk
I have many 3cx running. With the new app I get SSL error. They work with the old app.
Do not update the app.
Reactions: enamchuk
Is there a way to bypass this please?
Reactions: enamchuk
FYI - I didn't have a certificate problem on my web server, but I did have a certificate problem on Secure SIP.
Reactions: Vali_3CX
when will the bug be fixed? When will the new version of the app come out?
How can the application be downgraded or where can I download the old version?
It's been going on for quite some time now and it's becoming a problem.
Thank you, Jan
Reactions: enamchuk
Jan, now that I understand what's going on, I'm not sure it's going to be fixed. v20 is much stricter about certificates, and that includes iOS/Android apps, even if you haven't upgraded your system. They see it as a feature, not a bug.
There is no problem with the ios app. If you use a selfsigned certificate that wont work at all! You need to use an real certificate.
Thank you gentlemen. I will deal with it tomorrow. I will share the progress. Jan
Graham Robertson
