SSL VPN Certificates - issue and renewal - Debian
CSerpent
I spent a whack of time earlier this week trying to piece together the correct way to renew the SSL cert for our full non-3CX-FQDN server. For the benefit of others, I just wanted to share the procedure of how to sort your own SSL cert. We use thesslstore for our cert, but so long as your provider issues PEM certs, you should be fine.
SSH into your server and elevate to root
cd /var/lib/3cxpbx/Bin/nginx/conf/Instance1
openssl req -new -newkey rsa:2048 -nodes -keyout [your.fqdn].key -out [your.fqdn].csr
Fill in details, issue CSR to SSL provider, authorise issue.
Download Individual .crt files with a .pem extension, extract files
Upload extracted files via WinSCP / FileZilla / client of your choice to /var/lib/3cxpbx/Bin/nginx/conf/Instance1
mv [your.fqdn].key [your.fqdn]-key.pem
mv [your.fqdn].pem [your.fqdn]-crt.pem
systemctl restart nginx
I hope that helps anyone encountering this issue.
Reactions: CSerpent
Graham Robertson
