Standalone DECT Phone without SBC or router phone
AlexanderJHanna
Good morning,
Anyone using a DECT phone without SBC or router phone? If so, which one and what's your experience?
I have a few clients that need only cordless phones at some locations but installing a router phone just adds unnecessary cost. Therefore, looking for a minimum solution.
Just a word of warning, some people on the forums have had mixed results.
Likely it's a networking issue on their side, but also might not be.
Thank you for this heads up!!
I've found the connection on the Yealink AX83H 's to be very good, perfect in fact if you have decent Wi-Fi, however battery life is light years behind the DECT equivalent.
This is true, DECT is superior with regards to power management, and has a dedicated band. A SBC is also the superior choice.
If you cannot do the above, there is also the bigger brother, the AX86R which is ruggedized and equipped with a larger battery.
Agreed, a bit more pricey (and heavier) but a worthwhile upgrade for the battery life alone.
RJenkinsROCK
