StartUP Pro or StartUP
jpalmer2007
When I review the “my system” section of 3CX’s website, it says I have StartUP Pro. When I click on upgrade, it tells me my system is using StartUP. How can I tell which version I have?
Hello @jpalmer2007,
From your 3CX Portal you can check exactly which version you have:
If you click the Upgrade button: 1673823283369.png you can select the Version you can Upgrade to:
Available option should be to change the number of extensions to 20.
that worked - thanks
Netflo
