Support of Telefonica Germany (O2) multi-service router
1ama
we have an OneAccess One425 multi-service router from our provider (O2) that realizes a so called All-IP connection.
Does anybody know if that scenario is supported by the 3CX PBX?
Thanks a lot.
The device appears to support analogue telephone circuits. Are you planning on using these through a service from your provider? If so, then the ports normally used by 3CX may be reserved for those services and unavailable for 3CX . It may depend on the configuration options in the device.
Ok, for anyone who will have same question one day: It is supported.
Just "Add SIP Trunk", select Generic:
9962
and enter your provider creds, where Registrar is the OneAccess425:
9963
For us, luckily no further configuration was required.
kevlaboom
