Sync company phonebook between two 3CX installations
chrisdixon2
Forum User
Does anyone happen to know a way of syncing the company phonebook between two separate 3CX installations? We have users at both sites so it'd ideally need to be a bi-directional transfer. at the moment users are manually adding/deleting numbers from both but as humans do they don't often remember too!
Cheers
I'm not aware of this being an option at present.
Like Leejor said surely impossible for now , but perhaps you can turn over by installing only one 3CX in cloud, so just one phonebook to update :)
Unfortunately one in the cloud is not sufficient as I am required to have the sites run independently :-/
Another solution, depending on the phone.
You could manually add the remote address book, via the phone gui frontend.
For example on Yealink, goto Directory - Remote Phone Book and add the settings for the remote address book.
It is not an ideal solution, as you will have two address books
Reactions: CentrexJ
Call_Flow.co.uk
