Sync number from M365 to DID
JbJansson
Could it be correct that there is no way to sync from M365 to the DID number on a user ?
I have a costumer with 600+ users who wants to have alle users synced from M365, but do I really need manually to assign these users the DID number for inbound call after the sync from M365?
This will take me days.
Thanks in advance.
Jesper
If you refer to the outbound caller ID under the user's extensions, this option can sync from the Office phone number set under the M365 user account settings.
Thank you for your answer,
No i mean the assigned DID number on the user.
This is a 3cx feature that relies solely on the DIDs that are added to the trunk so there are no options to sync this from 365.
