Sync Presence from Soft client to handset
andrew@cellular-solutions
Platinum Partner
Is it possible when changing your presence status in the PWA for that to auto sync with a Yealink T54W handset, so when colleague are look at their own handsets they can see that a user is on DND for example?
DND is the only status that you will see on the phone.
This is a frequently asked question, I'm afraid this is not possible.
The BLFs on the phones show call state (not 3CX Status), so you can see only the following: Idle / Ringing / In call
You can see if your device is DND, but not the other users if they are DND.
Reactions: bitn2
Yes correct.. Only your own device not from any one else.
Finatra.us
