- Joined
- Oct 24, 2018
- Messages
- 367
- Reaction score
- 40
Trying to continue the thread from this... https://www.3cx.com/community/threads/crm-syncro-repairshopr-callerid-and-journal.72360/
I've implemented the xml in that thread. The outgoing calls are logging just fine, however the incoming calls are not logging at all. Would anyone have any idea what could be missing from that xml to not log incoming calls?
Thanks.
Thanks.
Code:
<?xml version="1.0"?>
<Crm xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" Country="GB" Name="Syncro" Version="1">
<Number Prefix="Off" MaxLength="11" />
<Connection MaxConcurrentRequests="2" />
<Parameters>
<Parameter Name="APIkey" Type="String" Parent="General Configuration" Editor="String" Title="API Key:" />
<Parameter Name="ReportCallEnabled" Type="Boolean" Editor="String" Title="Enable Call Journaling" Default="True" />
<Parameter Name="Domain" Type="String" Editor="String" Title="Domain:" />
</Parameters>
<Authentication Type="Basic">
<Value>[APIkey]:X</Value>
</Authentication>
<Scenarios>
<Scenario Id="" Type="REST">
<Request SkipIf="" Url="https://[Domain].syncromsp.com/api/v1/customers?query=[Number]&api_key=[APIkey]" MessagePasses="1" RequestEncoding="UrlEncoded" RequestType="Get" ResponseType="Json" />
<Rules>
<Rule Type="Number">customers.phone</Rule>
</Rules>
<Variables>
<Variable Name="ContactID" Path="customers.id">
<Filter />
</Variable>
<Variable Name="FirstName" Path="customers.firstname">
<Filter />
</Variable>
<Variable Name="LastName" Path="customers.lastname">
<Filter />
</Variable>
<Variable Name="CompanyName" Path="customers.business_name">
<Filter />
</Variable>
<Variable Name="Email" Path="customers.email">
<Filter />
</Variable>
<Variable Name="PhoneBusiness" Path="customers.phone">
<Filter />
</Variable>
<Variable Name="PhoneMobile" Path="customers.mobile">
<Filter />
</Variable>
</Variables>
<Outputs Next="" AllowEmpty="false">
<Output Type="ContactID" Passes="1" Value="[ContactID]" />
<Output Type="FirstName" Passes="1" Value="[FirstName]" />
<Output Type="LastName" Passes="1" Value="[LastName]" />
<Output Type="CompanyName" Passes="1" Value="[CompanyName]" />
<Output Type="Email" Passes="1" Value="[Email]" />
<Output Type="PhoneBusiness" Passes="1" Value="[PhoneBusiness]" />
<Output Type="PhoneMobile" Passes="1" Value="[PhoneMobile]" />
<Output Type="ContactUrl" Passes="1" Value="https://[Domain].syncromsp.com/customers/[ContactID]" />
</Outputs>
</Scenario>
<Scenario Id="ReportCall" Type="REST">
<Request SkipIf="[ReportCallEnabled]!=True||[CallType]!=Inbound" Url="https://[Domain].syncromsp.com/api/callerid.json/?did=[Number]&api_key=[APIkey]" MessagePasses="1" RequestContentType="application/x-www-form-urlencoded" RequestEncoding="UrlEncoded" RequestType="Get" ResponseType="Json" />
<Variables />
<Outputs Next="ReportCallMissed" AllowEmpty="true" />
</Scenario>
<Scenario Id="ReportCallMissed" Type="REST">
<Request SkipIf="[ReportCallEnabled]!=True||[CallType]!=Missed" Url="https://[Domain].syncromsp.com/api/callerid.json/?did=[Number]&api_key=[APIkey]" MessagePasses="1" RequestContentType="application/x-www-form-urlencoded" RequestEncoding="UrlEncoded" RequestType="Get" ResponseType="Json" />
<Variables />
<Outputs Next="ReportCallOutbound" AllowEmpty="true" />
</Scenario>
<Scenario Id="ReportCallOutbound" Type="REST">
<Request SkipIf="[ReportCallEnabled]!=True||[CallType]!=Outbound" Url="https://[Domain].syncromsp.com/api/callerid.json/?did=[Number]&outbound=true&api_key=[APIkey]" MessagePasses="1" RequestContentType="application/x-www-form-urlencoded" RequestEncoding="UrlEncoded" RequestType="Get" ResponseType="Json" />
<Variables />
<Outputs Next="ReportCallNotanswered" AllowEmpty="true" />
</Scenario>
<Scenario Id="ReportCallNotanswered" Type="REST">
<Request SkipIf="[ReportCallEnabled]!=True||[CallType]!=Notanswered" Url="https://[Domain].syncromsp.com/api/callerid.json/?did=[Number]&outbound=true&api_key=[APIkey]" MessagePasses="1" RequestContentType="application/x-www-form-urlencoded" RequestEncoding="UrlEncoded" RequestType="Get" ResponseType="Json" />
<Variables />
<Outputs AllowEmpty="false" />
</Scenario>
</Scenarios>
</Crm>
