System ext 700 keeps dropping off even on a new system
Vivaciti Ltd
I have an existing system that has an issue with ext 70 (conference) keeping dropping off, this was even after a restore, but it has never caused much of a problem, so gave up diagnosing it.
We today done a fresh install (enterprise) not done any restore so this is a clean build, it is a new VM on a different server (although same site), and before I have done anything so no sips only operator ext, no inbound or outbound rules, just a clean install with a new licence and I notice that ext 700 (conference) is again dropping off.
as its not doing anything else the logs are easier to see. All im getting is:
Extension 700 is unregistered, removed contact: sip:[email protected]:5483;rinstance=fe6dcc4e1d3e16fe, received from: 127.0.0.1
And then all on its own:
Extension 700 is registered, contact: sip:[email protected]:5483;rinstance=fe6dcc4e1d3e16fe, received from: 127.0.0.1
So I put the logging into diags mode, and now I get the bellow, still does not seem to help:
08/04/2020 15:29:04 - Default best-route IP is determined as 10.0.0.34
08/04/2020 15:28:05 - Currently active calls [none]
08/04/2020 15:28:49 - Default best-route IP is determined as 10.0.0.34
08/04/2020 15:28:44 - Endpoint Conf:700 has removed contact <sip:[email protected]:5483/UDP>
08/04/2020 15:28:44 - [CM504002]: Endpoint Conf:700: a contact is unregistered. Contact(s): [sip:[email protected]:5483 / 700]
08/04/2020 15:27:46 - Endpoint Conf:700 has added contact <sip:[email protected]:5483/UDP>
08/04/2020 15:27:46 - [CM504001]: Endpoint Conf:700: new contact is registered. Contact(s): [sip:[email protected]:5483 / 700]
08/04/2020 15:27:46 - Updating device Dev(467910291):[sip:[email protected]:5483;rinstance=fe6dcc4e1d3e16fe / 700] by message: DevUpd Recv Req REGISTER from 127.0.0.1:5483 tid=2d32c968ef4e3a74 Call-ID=9f-vnGSsR7q76Ni08Nnrgg..: REGISTER sip:127.0.0.1:5060 SIP/2.0 Via: SIP/2.0/UDP 127.0.0.1:5483;branch=z9hG4bK-524287-1---2d32c968ef4e3a74;rport=5483 Max-Forwards: 70 Contact: <sip:[email protected]:5483;rinstance=fe6dcc4e1d3e16fe> To: "Conference Room700:"<sip:[email protected]:5060> From: "Conference Room700:"<sip:[email protected]:5060>;tag=eae3ac38 Call-ID: 9f-vnGSsR7q76Ni08Nnrgg.. CSeq: 113 REGISTER Expires: 60 Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE Proxy-Authorization: Digest username="700",realm="3CXPhoneSystem",nonce="414d53595e8ddf6237:6a32b45c3bab3e26183128ea1db611aa",uri="sip:127.0.0.1:5060",response="269f257d19a8abe7cd422d3b19f3d203",algorithm=MD5 Supported: replaces User-Agent: 3CX Conference Room Content-Length: 0
Seems to be every couple of mins.
Anyone got any ideas before I put this into production.
Cheers
Bluebox Global
