System not saving 3 days of logs
c.holloway
Gold Partner
I have a 3CX 15.5 instance that isn't saving move than half a day's logs even though its set to save 3 days. I've both checked the web GUI and created a support file so I can view the logs in the Bin Log Viewer and the result is the same, the logs only go back to 11pm last evening.
The maintenance is expired and I'm working on getting that updated but I'm unsure if there is a link between the two. If the maintenance is expired, will this affect logging?
