System Prompts Bugs
skywaveorg
This issue has been around forever, but a few problems with the System Prompts interface that would be great to have fixed.
First, after every 3CX update, I ALWAYS have to update the US English set from 4.0.2 to 4.0.3. It seems the updates have never packaged the 4.0.3 version?
Second, the web interface sticky header for System Prompts doesn't work as expected, selecting a language to download doesn't update the header button to allow downloading it.
Here is a screenshot:
Can this be fixed?
Thank you!
Actually it looks like the sticky header is for the system prompts table below it, it just appears early.
The only issue then is the US English set always requiring an update to 4.0.3 after every 3CX upgrade.
Does the english prompt set actually require the update as in the used english promptset prompts dont function?
Never really update these much and i have never had a prompt not work after an update.
No it does not require it AFAIK, but it's still saying there is an update available after every 3CX upgrade.
Then you can hardly call this a bug and downloading these prompts after every update , wich is optional.. hardly takes any time whatsoever.
The fact remains that 3CX upgrades don't have this updated version packaged. A bug is a bug and if system prompts are bundled with every upgrade then they need to be updated.
WinSip
