Solved System Prompts Language
infinity5
Intermediate Cert.
Installed V18 from fresh on Azure, system installed with the default System Prompt Language (English American) although through the PBX Express wizard I selected UK English Prompts.
I have changed the System Prompts to us UK English and restarted all services but all prompts are using the American voice.
Have I missed something else?
Did you download the UK English Prompts ?
System Prompts -> Updates
Which prompts are still American ?
If you are referring to extension voice mail, you need to change it to UK English
Same applies to IVR, you need to change it
Same applies to Queues, you need to change it
Glad to see you found the solution @infinity5. Feel free to open a new thread if you require any further assistance.
GP Concepts
