T46s Call park
James Dyke
Hi Guys,
can someone point me int right direction of creating park key on the above phone?
Cheers.
From console , same place as BLF
11905
As above, just make sure the required phones in the same group have the same shared parking locations
You can specify the number of shared parking locations - Settings - Call Parking Settings (max is 50)
Hi, how is this achieved on the phone its self?
i can see call park and pickup
So i have set Call Park with a value of *01 and a label of Park1
I then set Pickup value *11 and a label of Pickup1
How can this be done with shared parking.?
Parking via 0/1 is NOT the same as Shared Parking. Please see : https://www.3cx.com/blog/docs/call-parking/
Normally, if you are using 3CX phone templates, choosing a BLF as Shared Park should do the trick. It will be configured automatically on provision.
Use shared parking, much easier to use.
What phones are you using ?
Change your BLF keys with 3CX management console to shared parking as per info in
aws2p post
When you want to park the call, you press the required BLF key - this will park the call. To pickup the call you just press the correct blf key on another phone.
aws2p post
T46s, problem is loads of BLF have been already set not to mention logos and user pictures, SO don't want to use auto provision as it will wipe out these settings.
These are the settings for shared parking
11908
SPx - is the Shared Parking location
SP x - is the label
Reactions: James Dyke
SP x - is the label
Hi, added the call to sp1 worked but then trying to pick up the call says "not found?"
This is for the original phone, if another extension pickup up then it works.
Hi James,
Ignore that post, it's regarding an old version. Try adding it from the management console and reprovisioning the phone, it will show you SP1 for example and you can test the functionality immediately to see what I mean:
- If you park a call, then both you and your colleagues can pick it up from that Shared parking spot.
- A Shared Parking BLF will show you whether there is a call in it by turning the LED red on the T46
As for these, if you set them via the management console they will not be lost, and you can also rearrange them accordingly. This is the correct and automatic way to do it.
Hi, but the logo's on the phones will be lost, unless i have the enterprise license.
@JohnS_3CX
James said previously he doesn't want to use MC not ot have a reprovisionning done on phone to avoid to loose settings already done .
Do what I did : copy the default template as a custom one, and only change the wallpaper in it. This way, you have the dial plan/BLF working without loosing the wallpaper.
Be aware that when in need of support, you'll need to reprovision with the official template.
@JohnS_3CX Are there plans to change the licensing on the wallpaper feature? I just feel like Pro and even Paid Standard should have this feature too. Not just Enterprise. Most of my custom templates are simply for the wallpaper or the Grandstream weather. That's all. Free licenses could be blocked to use 3CX logo, which is alright.
[email protected].
