T54W 96.86.100.5 - Syslog Changed and Remote Dial Option no longer working.
Julian_Hook
May I report ..
Problem 1:
Firmware 96.86.100.5 = The Syslog Facility & Syslog prepend MAC options have disappeared from Settings > Configuration > Syslog
Firmware 96.86.0.72 = Both options present
Problem 2:
Firmware 96.86.100.5 = Remote dial not working using .. /servlet?key=number=<number_to_dial>&outgoing_uri=1@<ipv4_Address>
Firmware 96.86.0.72 = Remote dial using above works
3CX Version : 18.0 Update 5
Thank you
Julian
Hello Julian,
Thanks for reporting. Please follow the above thread and we will update it as soon as the fix becomes available.
Yealink is working on producing the fix now.
Mahlon
