T57W Router Phone - Whoops
B-C.Elk
https://www.3cx.com/community/threads/t57w-as-a-router-phone-not-able-too-register.124975/page-2
Using StartUP
Reading this found that I initially setup without the right firmware and it got blacklisted..
What is the process to correct this?
Has now been about 12 hours so it should auto unblacklist at some point?
Deleted phone and verified SBC also removed...
re-added phone - factory reset phone
had to manually download the cfg file and import but no registration seems to be getting sent.
several reboots no go... all due to initial registration on factory firmware I'm sure!
have log files available - can't remember if attachments are public... but not major if I need to post those as well.
It’s a 24 hour window, or you can open a ticket and have 3CX remove the IP.
Reactions: B-C.Elk
Stephan Eusebe
