T58 showing firmware available when on latest version
mccarthytech
I have a T58 that has been manually provisioned for years that I decided to let be provisioned after the v20 update and it is now showing a firmware update available but when I dig in to see what version it's trying to upgrade to, it's a much older version than what's installed on the phone.
3CX Staff: Is there any way that the "supported firmware version" can be caught up to the actual latest version for this phone model?
Screenshot below for details.
The firmware provided by 3CX has been tested by both Yealink and 3CX for compatibility.
We receive firmware from the vendor, we then run it through a barrage of tests before releasing it. The firmware provided by 3CX is the supported firmware provided for each particular version.
We do not recommend running any other firmware versions.
Stephan Eusebe
