Telnyx missing from Add Trunk in SMB. can I reuse my existing template?
Astalada
SMB User
Hi everyone,
I’m using 3CX SMB and successfully added a Telnyx SIP trunk approximately two weeks ago, possibly through the initial setup wizard. It works correctly and shows “Built-in Template: telnyx.pv.xml.”
I now want to add a second trunk from a friend’s separate Telnyx account. We want to share one 3CX system while keeping separate extensions, phone numbers, and Telnyx billing.
However, when I go to Voice & Chat → Add Trunk, Telnyx isn’t listed under USA. Under Worldwide, I only see Twilio.
I understand that SMB is restricted to approved “3CX Tested” templates, while Telnyx is listed as supported under a different testing category. What I don’t understand is why I could add it so recently but cannot add another now.
  • Is there a difference between the providers available during initial setup and those available through Add Trunk?
  • Can I reuse the existing Telnyx template for a second trunk with different SIP credentials?
  • If this isn’t possible in SMB, what is the minimum deployment or edition that allows it?
I want to preserve my working trunk, so I haven’t clicked Sync Template or changed its configuration.
Thanks for any guidance.
f8bar
