Templates with capital letters
giwm
Forum User
I'm not certain when this change was made, but is it intentional that you can't save a template with capital letters in the name? A few of the factory templates use them and all my custom ones do. It's just an odd choice to disallow these.
Hello giwm,
You are correct, this is by design. Linux is case sensitive and when we first moved to Linux, this was an issue. Hence the restriction to lower case letters only.
Thank you for the speedy response. If only there were an easy way to mass change the template that a group of phones use, I could actually update them to an all lower-case one. :( Seems to be working as is, so not worth that effort.
fngl
