the 3cx console is opening my router page
Check under parameters for web_root.
Also please verify you are really using 5001 as https port on your 3cx. Internally you are reaching the pbx over 443 (as your screenshot).
Where you can see this?
Has the Firewall Checker passed: YES”
“HTTPS port is 5001”
“reason I don't use the 5001 at the end of my URL is because it don't work in that way”
[screenshot of management console not using 5001]
You can see why we’re confused?
See if this helps with your model router: https://www.3cx.com/docs/cisco-router-configuration/
Does the firewall tester still pass or did you only run it once?
Did you forward port 443 to your 3CX server?
Reactions: bitn2
Reactions: bitn2
This is sorted
Reactions: bitn2
No members online now.
RJenkinsROCK
