The ability to just enable/disable 1 SIP trunk only, not all trunks
networknotifications@mortgagehouse
Is it possible to just enable/disable 1 SIP trunk only (not the whole lot)?
If not can this be added to a feature request as this is silly that you have to enable/disable ALL trunks, as sometimes you need to test links on different boxes (production and staging) and you need the same links on both but only want to enable/disable them when performing testing and you don't want to keep having to add/remove them all the time
You can edit the trunk you want to disable, go to options and unchecked allow inbound and allow uutbound calls.
I know I can edit the trunk but I want to be able to enable or disabel the trunk in the CORRECT location IE the SIP Trunks page
The disable button disables the 2 options suggested by @jcostlow so that is the correct way of disabling one trunk.
I know there is no dedicated button in the SIP trunks page but to disable one trunk its just 4 clicks so still better than having to delete the trunk and recreate it for testing.
Reactions: Alan NZ
Senergia
