@Frank Yu
In Call Queues, the default behavior is for the MOH and Intro prompt to be played simultaneously. You could insert silence in the beginning of the MOH file which should be equivalent to the intro prompt duration.
if the agent answer the call during the middle or the end of MOH, it will have voice in background.@Frank Yu
the management want us to introduce company when music on hold , but voice record reminder before agent pick up the call . it's should be in different period.Normally MOH should be music only, and intro prompt with a speaked message, so when a call is active 3CX do a mix of both, and in that case there's no voices mixed from two different files sources
Or you could set a message added to music in MOH but in that case don't add another message in intro prompt
Do you mean that the intro prompt is played to the agent when they answer the call?if the agent answer the call during the middle or the end of MOH, it will have voice in background.
Founded in 2005, when VoIP was an emerging technology, 3CX has gone on to establish itself as a global leader in business communications.
