thoughts on supported phone models?
coreybrett81
I am researching for a new install which will have approximately 125 phones.
I will definitely be using one of the supported brands, but I'm not quite sure which one yet.
Does anyone have any stong opinions about the 5 supported brands and their various models?
Get hands on experience, order one of each and use them.
Maybe fast boot up time of snom phones is your thing, or you like annoying ringtones of Yealink. things you will never know if you dont get hands on.
I would go for the snom series.
- Different versions for each level of user
- Good prices
- Fast Boot
- Verry good support and FW update
- Works great with 3CX.
I have 5 sites with all Snoms.
But again. You only learn with hands-on.
For integration with 3CX Yealink are best and not too bad on cost. snom aren't too bad either but I believe cost a little more.
Snom (Americas) has new crazy promo coming out 10-1 that drastically drop the prices.
Only 1?? they're doing the same here in the UK but it's buy 10 get 2 free.
The Americas promo is different than the UK promo currently going on.
fngl
