Title: 3CX V20: Severe Intermittent Audio Breakup on Android/iOS with Dinstar LTE Gateway, Windows Softphone Works Perfectly
BilalAhmad
Hi 3CX Community and Support Team,
I am experiencing a persistent audio quality issue with a new Dinstar UC2000-VE Business 8-port LTE gateway integrated with 3CX V20.
Environment:
  • 3CX V20 Basic/Free 4SC, on-premises
  • Windows 10 VM hosted on Hyper-V
  • 3CX server: 192.168.200.24
  • Dinstar gateway: 192.168.200.23
  • FortiGate 61F firewall
  • Double NAT environment (Etisalat router + FortiGate)
  • 3CX Android and iOS applications
Issue:
Incoming GSM calls through the Dinstar gateway have severe intermittent audio breakup when answered using the 3CX Android or iOS applications.
However, the same incoming calls work perfectly when answered using the 3CX Windows softphone, including from a remote location.
Extension-to-extension calls between mobile applications also work perfectly.
Sometimes the GSM-to-mobile calls are clear, while other times the voice breaks severely, particularly during the first 30–60 seconds.
Troubleshooting already completed:
  1. Reinstalled 3CX on Windows 10 instead of Windows 11. No improvement.
  2. Tested multiple Android and iOS devices and extensions.
  3. Tested mobile applications over Wi-Fi and cellular networks.
  4. Adjusted codec priorities, including G.711 PCMU/PCMA.
  5. Enabled PBX Delivers Audio on the affected extension. No improvement.
  6. Disabled NAT on the FortiGate WAN-to-3CX VIP policy for testing. No improvement.
  7. Confirmed Dinstar LTE registration and signal strength.
  8. Confirmed the SIP trunk displays green/registered in 3CX, but the audio issue persists.
  9. Previously captured Dinstar RTP traffic without identifying obvious packet loss on the inspected gateway-to-PBX stream.
We also have another Dinstar UC2000-VE Business gateway working in a separate 3CX environment. The new gateway has a newer firmware version, but we have not changed its firmware.
Questions:
  1. Why would incoming Dinstar GSM calls work perfectly on the Windows 3CX softphone but break on Android/iOS?
  2. Could this be related to 3CX mobile tunnel media handling, transcoding, jitter buffering or RTP routing?
  3. Are there any known compatibility issues between 3CX V20 and Dinstar UC2000-VE LTE gateways?
  4. Which specific 3CX logs or packet captures would help identify the issue?
  5. Could the double NAT environment affect mobile-app media while leaving Windows softphone calls unaffected?
I am prepared to capture both working and failing calls using Wireshark, but I would appreciate guidance on the most useful capture points and diagnostic approach.
Any technical suggestions would be greatly appreciated.
Thank you.
LeeonLau
