Solved TLS SIP Trunk has broken after update
jrenshaw
Hi @jrenshaw
We made a small change to the PBX to avoid having to mess with the OS so you will need to navigate to Security / Anti-Hacking and disable the option "Enable PCI compliance SSL/SecureSIP Transport and Ciphers (This will leave only TLSv1.2 enabled and may prevent old legacy phones and old 3CX Apps to connect remotely to your system). Requires SIP service restart (Go to Dashboard, Services, Select 3CX PhoneSystem 01 SIP Server and restart)."
Once you do please restart your SIP server service by navigating to Dashboard / Services. It should be OK after that
Reactions: jrenshaw
Hi @YiannisH_3CX .
That's great. Thanks for the quick response. This has resolved the issue!
Many Thanks
Reactions: YiannisH_3CX
Glad I could assist.
awan05
