To get a single log file, you now have to request a “Support Info” package
EscondidoAdmin
Please restore the same functionality as in v18, in which from the Dashboard you used to be able to browse Logs and download just one.
Now, in v20, to get a single log, you have to request a “Support Info” package, wait for it to download and then get your file from an unnecessarily large zip archive. In our system, it takes over 4 minutes to complete the SupportInfo.zip file and it's about 5.5GB in size.
Example: I'm testing a Call Script that is failing. To troubleshoot, I'll make a change in the CFD, build it, then update the script. I'll make a test call and if still failing, I need to review the 3CXCallFlow.log I have to download the SupportInfo.zip which takes several minutes. Then, once I determine what the error is, I'll go back to the CFD and repeat the above process. wash, rinse, repeat. Debugging a Call Script change in v20 takes significantly more time if you need to perform iterative troubleshooting.
Upvote 6
Finatra.us
