Transitioning to 3CX 4SC Basic
Kevin Attard Compagno
Staff member
3CX Support
What you need to know about migrating from hosted to self-hosted.​
If you choose not to renew your existing 4SC PRO license, you will soon have the option to downgrade to the Free 4SC Basic edition. Before making your decision it’s important to note that the Basic Edition does not include 3CX managed hosting or IP Phones suppo...
Little confusion here
  • IP Phones: Support not included
i know 4 SC licenses are not supported ( tech support) from 3cx, so" IP phone Support not included " means IP phones cannot be connected / provisioned in 4SC Basic or
we can use 3CX free SBC and IP phones, but its trouble shooting is not supported ?
You will not be able to connect IP Phones to 4SC Basic.
Its not supported means it wont work. No ip phones on the basic system.
Reactions: N_G and fxbastler
The feature list has "Inbuilt SBC for Offsite Phones" checked for Basic, maybe a check-o?
Thats correct. With Basic you can use phones and SBC. Just the 4sc Free isnt working with sip phones.1771518126147.png
Ha, read right past the line I suggested. Good that's changed from the above discussion.
WinSip
