- Joined
- Feb 17, 2024
- Messages
- 18
- Reaction score
- 9
When attempting to send an SMS from the Windows client or the Android app, I get this error:
30030 Failed to send message(s) to the provider 'voxtelesys' from '+13209826703' to '+13203093923'. Exception: Cannot find provider for number +13209826703.
Trouble is that we don't use voxtelesys. We use Twilio. We did use voxtelesys but canceled it over a month ago. I've checked settings in the android and windows apps, and I don't see why 3cx says we are using voxtelesys.
We can send and receive phone calls no problem.
Is there some other location where I need to go to make sure the provider is set correctly for SMS? I know the Account SID and Auth token are correct, as is the web hook at Twilio. I know that I was able to send texts before, even after we switched to Twilio. This is confusing me.
