- Joined
- Jul 18, 2019
- Messages
- 110
- Reaction score
- 14
Hi.
We're trying to use a custom trunk with 3CX, it's a landline DSL provider which also assigns a virtual number. We tested the configuration with Zoiper and works fine. In 3CX we're able to receive calls but not to make outbound.
This is the message we get in logs:
(151.6... is the SIP trunk, 333123 is the called number, 10001 is the line id in 3CX).
Our speculation is that the sip:[email protected]:5060 param is wrong, it should probably be the caller (our) phone number. We tried changing From: User Part and Remote Party ID - Calling Party: User Part setting them to AuthID but didn't change anything.
It's almost certainly an outbound parameter which needs to be fixed to comply with the SIP provider, but so far we were unable to find which one. Any suggestion?
thanks
Code:
10/06/2021 12:36:26 PM - Call to T:Line:10001>>333123123123@[Dev:sip:[email protected]:5060] from L:29.1[Extn:032] failed, cause: Cause: 407 Proxy Authentication Required/INVITE from 151.6.93.169:5060
thanks
