Trunk/DID reports
treboR
Forum User
When I select the report for our DID's I am not able to add the "add trunks" to select which trunks I would like to report on. I am not able to figure out why.
Any suggestions would be greatly appreciated.
Hi @treboR,
A couple of questions:
  1. Can you provide more information?
  2. Does the PBX have a registered SIP Trunk(s)?
I am not sure as I have been in place to administer the system and there seems to be a bunch of missing parts.
Where should I look for the registered SIP trunks?
Hi @treboR,
In the Management Console you can click "SIP Trunks"
If you don't see the same menu, it's likely that you're not logging in to the Management Console as the Admin of the PBX.
d.obermeier
