Unsupported trunk not working
marzo82
we have 1 trunk ISP Telmex, but when we try to call or out call to this trunk not work, this is the error:
09/30/2021 12:36:15 PM - Malformed SIP request received:
BadSip Recv Req INVITE from 10.148.0.16:52868 tid=C9691877 [email protected]:
INVITE sip:[email protected]:5060 SIP/2.0
Via: SIP/2.0/UDP 10.148.0.16:5060;branch=z9hG4bKC9691877
Max-Forwards: 65
Contact: <sip:[email protected]:5060>
To: <sip:[email protected]>
From: "528127243680 " <sip:[email protected]>;tag=585D9034-D92
Call-ID: [email protected]
CSeq: 101 INVITE
Expires: 180
Session-Expires: 1800
Min-SE: 1800
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Content-Disposition: session;handling=required
Content-Type: application/sdp
Date:
Supported: 100rel, timer, resource-priority, replaces, sdp-anat
Timestamp: 1633023363
User-Agent: Cisco-SIPGateway/IOS-15.7.3.M
Allow-Events: telephone-event
Cisco-Guid: 3082591613-0558567916-2220737817-1554932602
Session-ID: 6bc5f819ad05528ca9bcf244a9e66da8;remote=00000000000000000000000000000000
Content-Length: 267
v=0
o=CiscoSystemsSIP-GW-UserAgent 5052 2671 IN IP4 10.148.0.16
s=SIP Call
c=IN IP4 10.148.0.16
t=0 0
m=audio 16574 RTP/AVP 18 101
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=ptime:20
any idea to resolve this.
thanks
regards
Dear Mr.Marzo82,
Kindly try this & remember that for each total dialing digits (10/12/16/20...etc) you have to make separate outbound rules.
DISABLED SRTP & set Transport Protocol as ANY + ADD / DEL the CODECs which approved by SIP provider, then try below outbound rule, if successful then try to change SRTP & Transport protocol but be sure that your SIP really authorized/work on this.
For Outbound calls, you should make the Outbound rules simply then it would work, as you made it already so here I'm re-writing which maybe re-gain you if you missed something:-
1. Calls to numbers starting with prefix
- 00
2. Calls from extension(s) - MENTION THE EXTENSION OR if more then add with comma BUT NO SPACE
3. Calls to Numbers with a length of - EXACT LENGTH, IF MOBILE NUMBER IS "0091 1234567890" = 14DIGITS SO MUST MENTION 14, IF DIALING LANDLINE NUMBER OR ANY OTHER COUNTRY WHICH MAYBE 12 OR 16 OR MORE THEN MAKE A SEPARATE OUTBOUND RULE FOR EACH AS one rule for one type of dialing. Each Outbound rule will auto-detect, don't worry.
4. Calls from extension group(s) -
leave it OR if you made DEFAULT group & Want to give the access to all then add the same group.
5. Make outbound calls on - In the Route 1 choose SIP name then choose 0 in Strip Digits, leave Prepend blank, choose Outbound Caller ID
Dial like this 0091 1234567890 where 00 triggers the OUTBOUND RULE & as an International call + total 14digit trigger the exact length for this rule.
Save it & try...
B.regd
Mayank Gupta
lastshadow
