Trunks in 3CX v20 Dashboard
yevpro
SOHO User
We have several sip-trunks. After migration to v20, interface has changed and now in dashboard we see an error because some VOIP providers are not supported by 3cx.
Is there any way to make a provider "trusted/verified" so that we see that error in dashboard only in case the sip-trunk is down?
Basically yes, it depends on the answers to the following questions:
  1. What kind of trunk was originally used as a template?
  2. Can you still access the trunk in the administration to change anything?
  3. What kind of 3CX license are you using?
  4. Is it a Windows or Linux 3CX?
  5. Do you have access to the 3CX system (any kind of a shell)?
This is an indication for the generic provider template that is in use, under the Voice&Chat section you also see the reason:
Yes, thats our case. We are using generic voip provider. But the trunk in active. So its confusing to see in dasboard an error.
I am ok to see the warning on the Voice&Chat page, but not on the dasboard page.
1) Generic VOIP Provider
2) Yes, I can
3) PRO4SC
4) Linux VM from 3cx Azur template
5) Yes, I have full control.
Not supported: replace the template file name in the database.
Per example:
  1. list all gateways and their template name
    select idgateway, name, model from public.gateway;
  2. change #2 to the dts template (file must exist in the template directory, customize idgateway as needed):
    update public.gateway set model='dts.pv.xml' where idgateway=2;
    commit;
  3. reboot 3cx
This way you keep the complete setup: DID, names, assignment, outgoing rules, etc..
Reactions: bitn2
LeeonLau
