Solved Try License
siscom
Good Morning Colleagues
I hope you are doing good . I am 3CX Affiliate partner and i have tried to create trial license for one of my new customers for testing purpose. Previously , I was able to create 3CX Pro License that should last for 45 days but the trial license that created was Standard 8 CC.
So does anyone know the reason for this ?
Best Regards
Hi @siscom,
As a partner you can create a Standard 8SC license then upgrade it to a 60 day POC (proof of concept) key which provides the option to trial PRO / ENT edition features. To do this log in to the Partner Portal, and click Keys. Select the Key you wish to upgrade to POC and click 'More' then 'POC'.
You can find more FAQs pertaining to partners here: https://www.3cx.com/partners/faq/
Thx so much for your support . It worked for me perfectly
Kayla Norris
