Try the latest Android Beta for Speedier Performance
Vali_3CX
Staff member
In this beta we made some final touches and improvements to provide you with a more reliable and seamless calling and messaging experience.
Even better connectivity​
We’ve fine tuned the app for faster call connectivity and improved reliability. The built-in tunnel has been optimized to:
  • Be more responsive to network...
Reactions: jed
The biggest issue I currently have is with my phone that the app continues to ring if I already picked up the call with my phone, because my phone SIM is integrated with 3CX.
If you turn OFF the "Also ring my mobile" option in 3CX client it does solve the problem?
Grazie dell'aggiornamento, con la versione precedente il mio S21 utilizzato con il Blueth nella mia Jeep Compass serie 2018 funziona abbastanza bene. Avevo rilevato che durante la composizione della chiamata lo squillo non passava direttamente nel sistema audio della macchina ma il passaggio avveniva solo dopo che la persona chiamata aveva risposto.
Quando connetto il mio S21 entra in automatico Android Auto ma l'applicazione 3CX NON è ancora compatibile ma comunque riesco a riceve le chiamate e riesco anche a farle digitando il numero dal telefono.
E' necessario che anche 3CX implementi la compatibilità con Android Auto!!!
We try to do our best.
Putting the 3CX to silent kind of fixes this issue, the SIM is registered to the extension, so ring my mobile doesn't affect this case.
I updated today my app, problem on my Samsung Galaxy A8 (2018), the bluetooth option need to be disable to not get one way audio, but it seems that the option re-ticked itself after the update.
I'm in beta version, I could understand but the same will happen on stable ?
We made some improvements in Telecom API functionality - have you tried this beta with Telecom API enabled, to see if it's working OK? Please let me know.
Reactions: accentlogic
Jeremy Hofex
