Trying to add IP phones
rapid6
Should I be able to select one of these radio buttons? This is the second UI since deploying the PBX we've found that we can't interact with.
@rapid6 what is the browser you are using ?
Also do you have any SBC setup on the PBX side ?
What is the model of phone you are trying to setup ?
FF, tried in private mode, same result. Also in Chrome.
No SBC, I believe we can connect the phones directly (but I can't get the provision URL until I can get past this screen but can't select and radio button).
Yealink T42S
v20 Pro / 16 calls / 3cx hosted.
T42s isnt an router phone. You need at least an T42U or install an SBC somewhere else.
Reactions: N_G and JohnS_3CX
Yes, thats what i said...
It can be a VM, or installed on any Windows PC. It just needs a constant IP address.
They have no physical machines on site.
KylieWilderman
