Trying to add Telnyx as a trunk - "main trunk NO"?
survivalbloke
I'm not sure what to put here. I did find some other forum posts talking about putting a "DID" there but then I couldn't figure out how to create a DID.
I just signed up with Telnyx and I've not yet ported any numbers to them. What do I do from here?
You can register a temporary number in Telnyx and use it as a test DID or just put 5 zeros to create the trunk with a dummy main number. You can add/edit later.
Reactions: YiannisH_3CX
Hi @survivalbloke
You could do what @ConceptsWeb suggested and just use a dummy number there to create the trunk and change it when your numbers are ported. But without numbers why create the trunk? I would wait for the numbers to be ported so you can test everything properly.
bunthoeun.may
