Solved Twilio SMS problem
DiverseyAG
we have done the whole configuration with Twilio. But on twilio side we get an error from 3cx server "Error 500: Internal server error".
What can we do? I have also attached our Management log and a picture of Twilio error!
Please help us!!
Best regards
Patrizio
[Logs deleted by administrator]
HI @DiverseyAG
In the logs you sent (which you shouldn't make public as they contain sensitive info) i can see that Twilio is reporting error 21606.
Twilio has a document explaining what this error is and how to resolve it: https://www.twilio.com/docs/api/errors/21606
In short make sure that the number you are using is SMS capable, you are using the correct caller ID and your number is formatted in the E164 format.
j.hereijgers
