uElastix on Raspberry Pi and USBfxo .. help?
Aiiar
I have downloaded the image file which was available on uelastix.org and burned it on the SD and worked well on the raspberry-pi.
Now I want to install the sangoma USBfxo on the pi and I think it is very important because it is the smallest and cheapest solution to work with pi.
I have followed the instructions listed here:
http://wiki.sangoma.com/Voicetime-Elastix-Installation
and for steps 2 & 3, I have downloaded the dahdi version (dahdi-2.6.1-1.src.rpm) from here:
http://repo.elastix.org/elastix/2.0/beta/SRPMS/
for step 5, when I write the ->rpm -i dahdi-2.6.1-1.src.rpm
I didn't get any response! nothing happend!
then the instructions in step 6 not work.
I need help please in this problem, and please note that I have a very little knowledge with LINUX.
another problem.. the CLI (dos) massages are in Spanish language, how to change it to English?
I have changed the language from Spanish to English at the web interface, but at CLI black screen is still Spanish!!?
And why in this uelastix version,when I write >steup ,
I got this: -bash: setup: no se encontr?? la orden
why not login to setup screen!!?
Thank You all.
no one can help me!?
To change language look at the Linux help pages:
http://stackoverflow.com/questions/1108 ... e-on-linux
Not sure why you're having install problems - but I'm also interested in using the Pi for Sangoma U100 FXO USB - was planning on getting one in the next few weeks - will let you know how I get on
CLTedu
