Solved UK Gamma calls to 01164 (Leicester) blocked
double6jg
3CX Country Blocking Feature [01164]. Reason: 01164026500 contains Prefix 01164. Calls to 01164 are not allowed by system. Resolution: To allow this call access the 3CX Management Console, Settings, Security, Allowed Country Codes and enable the country or continent that matches this prefix.
The question is - which Country does 3CX think is 01164 is?
SOLVED with an Outbound Rule to strip 0 and replace with 0044 but still interested to know where 3CX thinks 01164 is located?
Glad you figured it out!
If I had to guess, it probably has something to do with the options in Settings --> E164 Processing.
If you have this enabled, what do you have in the international dial code?
@NickD_3CX
You are right.
I'd not touched that and it was set to Enabled, Country (USA) with an international access code of 011 which I guess is the default out of the box setting. Now corrected.
Reactions: NickD_3CX
That was it!
I'll set this as 'Solved'.
Mr_IT
