Solved Unable to add new users to an existing call queue
markoh
Hi all,
I recently onboarded some new staff members and set each of them up with an extension on 3CX v20.0 (Build 1620). Each person has been assigned to a department, but when I try adding them to an existing call queue there is no Users tab appearing (there is if I try creating a new call queue).
Does anyone know of a workaround for this?
Thanks in advance.
Is your existing Q in the same dept as the user trying to edit?
Yes, I'm fairly sure I had previously only needed to ensure the users were added to the relevant department and they were automatically added to the queue, but this is not happening now.
Hi there.
Is this screenshot if you log in as a system owner user?
@OlegR_3CX would you have any advice on how to resolve this issue?
I need to get these new hires active on the call queues sooner rather than later.
I figured out what was going wrong here - user error!
I have the new hires added to the correct call queues now (had mistakenly been looking at a GRP extension previously)
Reactions: OlegR_3CX
Thank you for the feedback and glad you have found the source of the issue.
I will now close this thread.
ARKC
