Unable to Answer call without pressing New Line
a.ha
Hi there
We have suddenly started facing an issue where every call that comes into our T58A
You have to press Line 1 before it lets you answer it
Same for outgoing, instead of just picking up the handset and start dialling, you have to press Line 1 first
I'm not sure if the user has changed something by mistake
But I cant for the life of me figure it out
This shouldn't be the case. Have you tried to factory reset and reprovision?
not yet. as they have a second account on there for the intercom that we dont know the password for
Are you using 2 extensions on the same device?
no, just the 1 EXT
You have mentioned " a second account on there for the intercom", where is this second account configured?
This second account is manually added as its an intercom system.
it doesn't have an EXT, it just calls the phone directly when someone presses the intercom
Can I export the 2 Accounts and then factory reset it?
I know 1 will be added back via autoprovision
So this is a manual configuration on the phone correct?
no, auto provision for the main Reception account
then we had to manually add the second account for the Intercom
Adding a second account to the device is not tested neither supported from 3CX.
lovely, thank you
You are welcome ;)
SupportRock
