Unable to answer ring group call, backup phone rings also and can answer - intermittent
Samson
Hi there,
I've scoured these forums for somebody with a similar issue as me, but I can't seem to find anything the same, so here goes...
I've got a local 3CX windows installation 15.5.15502.
I'd say 90% of the time it all works as expected, all desk phones ring in the ring group and can be answered or it goes to VM. Great!
However that other 10% is the doozy.
The desk phones will all ring and appear normal (displaying the caller id of the person calling), but after you lift the receiver the call ends immediately. This happens with all extensions.
However, with my VoIP provider, Engin (Australia), they have a reach me feature, so in case I lose internet at the office a backup mobile/cell phone can take the call.
And when the above issue occurs, the mobile/cell phone rings also - and the call can be answered from there.
Answering the call on the mobile/cell does not stop all the desk phones ringing. They will eventually time out, or everyone picks up their phones and hangs up again.
The internet has not gone down when this happens.
I have another office with a pretty much identical - as far as I can tell, 3CX installation in a different location, same ISP, same VoIP provider, same SPA942 or 504G handsets but this issue does not occur.
I've increased my logging to medium and caught and instance when it occurs, see below.
If anyone has any insight to this unbelievably hair pulling error, I would greatly appreciate it!! Thanks!
02/10/2019 15:25:57 - Currently active calls - 1: [144]
02/10/2019 15:25:52 - [CM503008]: Call(C:147): Call is terminated
02/10/2019 15:25:52 - Leg L:147.1[Line:10000<<0425844162] is terminated: Cause: CANCEL from 203.161.160.71:5060
02/10/2019 15:25:52 - [CM503025]: Call(C:147): Calling T:RingAll:800@[Dev:sip:[email protected]:5060,Dev:sip:[email protected]:5060,Dev:sip:[email protected]:5060] for L:147.1[Line:10000<<0425844162]
02/10/2019 15:25:52 - [CM503027]: Call(C:147): From: Line:10000<<0425844162 (<sip:0425844162@RemovedOURFQDN:5060>) to T:RingAll:800@[Dev:sip:[email protected]:5060,Dev:sip:[email protected]:5060,Dev:sip:[email protected]:5060]
02/10/2019 15:25:52 - [CM503004]: Call(C:147): Route 1: from L:147.1[Line:10000<<0425844162] to T:RingAll:800@[Dev:sip:[email protected]:5060,Dev:sip:[email protected]:5060,Dev:sip:[email protected]:5060]
02/10/2019 15:25:52 - [Flow] No office hours set, office hours assumed
02/10/2019 15:25:52 - [Flow] Target endpoint for 100 is Extn:100
02/10/2019 15:25:52 - [Flow] Target endpoint for 102 is Extn:102
02/10/2019 15:25:52 - [Flow] Target endpoint for 101 is Extn:101
02/10/2019 15:25:52 - [Flow] Call(C:147): has built target endpoint: RingAll:800 for call from L:147.1[Line:10000<<0425844162]
02/10/2019 15:25:52 - [Flow] Target endpoint for 800 is RingAll:800
02/10/2019 15:25:52 - [CM503010]: Call(C:147): Making route(s) from Line:10000<<0425844162 to <sip:[email protected]:5060>
02/10/2019 15:25:52 - [CM505003]: Provider:[Generic SIP Trunk] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:removedOurNumber@removedOurStaticIP:5060]
02/10/2019 15:25:52 - [CM500002]: Call(C:147): Info on incoming INVITE from Line:10000<<0425844162:
Invite-IN Recv Req INVITE from 203.161.160.71:5060 tid=33o126104oifujee4cs0.1 Call-ID=SDnr1sd01-749d463129d5ff69ef79efcec306b0ef-jm6gpa0020:
INVITE sip:removedOurNumber@removedOurStaticIP:5060;rinstance=0ee8004a0d516a07 SIP/2.0
Via: SIP/2.0/UDP 203.161.160.71:5060;branch=z9hG4bK33o126104oifujee4cs0.1
Max-Forwards: 29
Contact: <sip:[email protected]:5060;transport=udp>
To: "removedMyName"<sip:[email protected];rinstance=0ee8004a0d516a07>
From: <sip:[email protected];user=phone>;tag=SDnr1sd01-2073987581-1569993919065-
Call-ID: SDnr1sd01-749d463129d5ff69ef79efcec306b0ef-jm6gpa0020
CSeq: 91686189 INVITE
Session-Expires: 1800;refresher=uas
Min-SE: 90
Accept: application/media_control+xml, application/sdp, multipart/mixed
Allow: ACK, BYE, CANCEL, INFO, INVITE, OPTIONS, PRACK, REFER, NOTIFY, UPDATE
Content-Type: application/sdp
Supported: 100rel, timer
Recv-Info: x-broadworks-client-session-info
Content-Length: 365
v=0
o=BroadWorks 44177089 1 IN IP4 203.161.160.71
s=-
c=IN IP4 203.161.160.71
t=0 0
m=audio 23828 RTP/AVP 8 18 0 101
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=silenceSupp:off - - - -
a=ptime:20
a=maxptime:30
a=sqn: 0
a=cdsc:1 image udptl t38
a=sendrecv
02/10/2019 15:25:52 - [CM503001]: Call(C:147): Incoming call from Line:10000<<0425844162 to <sip:[email protected]:5060>
02/10/2019 15:25:52 - Line limit check: Current # of calls for line Lc:10000(@Generic SIP Trunk[<sip:[email protected]:5060>]) is 2; limit is 10
02/10/2019 15:25:52 - [CM503012]: Inbound office hours rule (unnamed) for 10000 forwards to DN:800
02/10/2019 15:25:52 - [Flow] Looking for inbound target: called=removedOurNumber; caller=<sip:0425844162@:5060>
02/10/2019 15:25:27 - Currently active calls - 1: [144]
3CX Version: Standard Annual 15.5.15502
Server OS: Windows 10 Pro
Is the 3CX Server Hosted and where? No, local
IP Phone Make/Model/Firmware:
1x SPA-942 6.1.5(a)
2x SPA504G 7.4.9a
1x SPA504G 7.6.2d
Provisioning Method: Local
Trunk Provider: Engin (Australia) Generic SIP Trunk
Has the Firewall Checker passed: YES
Are custom Phone Templates being used: NO
You should try to update firmware for 504G, should be almost 7.61
https://www.3cx.com/sip-phones/cisco-spa/
can you try with App on mobile or PC and set these to a new RG for test and see if extension included in this RG works properly
Wecare_ITA
