Unable to change an extension number to another
sajeerhajib
I have created extension100 for one user ,right now i want it to make 101 .A message is showing it cant be deleted and error is also coming . What will i do. ? please find my attachment for
the reference
Hi @sajeerhajib,
Add a new extension 101 for your user. The extension 100 is reserved for your operator extension.
Hi @sajeerhajib,
Ah! In that case, simply change the operator extension in the Management Console >> Settings >> General to 200. Then you can rename / delete / recreate the 100 extension or whatever you'd like.
Zexus
