Unable to change the RECYAMSG
cam
I created a copy of the defaul prompt set and changed the RECYAMSG messgae a few years ago.
I want to change it again but nothing happens when I try to add a new wav file using the browse button.
I click browse, select the new wav, but the wav file doesnt change
Any ideas please?
Are you using the same file name when you browse in?
Reactions: cam
No, I did wonder that, do I need to use the same file name then?
Yes as the system will reference that.
Reactions: cam
Great, thanks - that worked.
costionofrei
