Unable to create bridge between 2 3CX servers
greychain
Gold Partner
Yes they are both running Enterprise and they have different licenses. They are our NFR licenses.
When configuring the slave I get this message.
Latest and greatest version.
What should I be looking at?
Have you confirmed that the PBX is able to activate first?
Yes , the key was still registered to a different fqdn not the 3cx.asia fqdn the server was using. How did it get a 3cx.asia fqdn with the key being bound to a different FQDN?
Have you used the key to another installation?
Yes it was bound to a different FQDN. I thought it was impossible to reuse a key if it was bound to a different FQDN. The systems are both using the same public IP, maybe that was the issue
Yes any such conflict can cause those issues. Please check and let us know.
It's fixed now and the master-slave bridge is working. For calls passed through the MB does this count as 1SC per server?
Jake_Southern
