- Joined
- Apr 7, 2023
- Messages
- 1
- Reaction score
- 0
I used the following article to https://www.3cx.com/voip-gateways/grandstream-ht-fxs/ to configure a brand new Grandstream HT812 analog telephone adapter for use with a legacy fax machine. I will note that I was not able to update the device to the lates firmware [1.0.45.2] or the previous firmware [1.0.41.2] because the device kept giving an error that the firmware file was to large. I was able to update it to firmware 1.0.39.4. Anyway, the incoming dialing works perfectly and I was able to receive a fax. However whenever I try and dial out with the fax machine or use an analog device to dial out inside of the 3CX PBX I am getting errors like this when I try and dial out with an analog device attached to the Grandstream HT812 analog telephone adapter
05/09/2023 4:02:30 PM - [Flow] Target endpoint for xxxxxxx00 can not be built!
05/09/2023 4:01:40 PM - [Flow] Target endpoint for xxxxxxx00 can not be built!
05/09/2023 3:56:05 PM - [Flow] Target endpoint for xxxxxxx29 can not be built!
05/09/2023 3:55:45 PM - [Flow] Target endpoint for xxxxxxx00 can not be built!
05/09/2023 3:46:19 PM - [Flow] Target endpoint for xxxxxxx00 can not be built!
05/09/2023 3:46:00 PM - [Flow] Target endpoint for xxxxxxx00 can not be built!
05/09/2023 3:42:02 PM - [Flow] Target endpoint for xxxxxxx00 can not be built!
05/09/2023 3:41:41 PM - [Flow] Target endpoint for xxxxxxx00 can not be built!
On the device itself I get either a fast busy signal or dial tone-break-dial tone when attempting to dial out.
I have reviewed the logs of the SIP Provider, Wiretap and it does not appear the calls are even reaching their system
