- Joined
- Dec 5, 2010
- Messages
- 22
- Reaction score
- 0
On V15 using the 3cx windows client we were able to dial to +972541234567. After the upgrade to V16 I now get an error on the activity log and the client imminently hangs
The activity log has the following
10/04/2019 4:47:19 PM - [CM503016]: Call(C:5): Attempt to reach <sip:+972541234567@ip:0> from Extn:241 has failed. Reason: Not Found
10/04/2019 4:47:19 PM - [CM503014]: Call(C:5): No known route from Extn:241 to target: <sip:+972541234567@ip:0/UDP>
10/04/2019 4:47:19 PM - Call(C:5): from Extn:241 to +972541234567 doesn't match any outbound rule. No outbound rule could be selected.
10/04/2019 4:47:19 PM - [Flow] Target endpoint for +972541234567 can not be built!
10/04/2019 4:47:19 PM - Looking for outbound rule: dialed = [+972541234567], processed: [541234567]; from-ext:
10/04/2019 4:47:19 PM - [Flow] Building target endpoint to +972541234567 from "Extension" <sip:241@ip:0>
I do have an outbound rule for numbers with prefix +972 and length 13 strip 4 digits and prepend 0 and send to the SIP trunk we are connected to (resulting in replacing +972 with 0 so the number would be 0541234567
What am I missing? As I said this was working in V15
