Unable to download new Elastix 2.5.0 Beta 2
gershte
The sf download count is zero, that means no one has been able to download it.
Whom can we contact to fix it?
Have already emailed the guys at Palosanto regarding this about 30 minutes ago.
I saw the issue yesterday, but left it another 12 hours to confirm that it was not a mirror sync issue.
We will just need to wait.
Regards
Bob
Regards
Bob
Thank you very much Bob!
Regards!
Just updating....I didn't get a response from the Guys, which to a certain degree I suspected as ElastixWorld is on this week (14th/15th). As they do every year, there is a lot of organisation that goes into it, and it becomes a single point of focus for the guys.
I have one suspicion which is that they may make the beta downloadable on or after the Elastixworld. They normally like to release something noteworthy around Elastix world, and as you can imagine, they would have done all the prep work on the website etc before the conference to make it quick to turn on (at the conference)...I may be completely wrong....but either way I have sent an email and wait for the next couple of days.
Regards
Bob
Hi all.
I chatted with Edgar, and he would try to fix this issue as soon as possible.
Edgar is in Mexico right now.
Regards
Now folder is empty...
yes I see the same - it is now empty.....however I note that it shows modified.
This may be the mirrors updating and may take 24 hours.....
either way as per Danardf's comments, they are aware of it, and just need to wait a little longer.
Regards
Bob
Me too. :D
Thanks for the Japanese Sourceforge link.
Now downloading from that link.
It appears that there is something wrong with some of the sourceforge mirrors.
If you are having troubles, use the link provided by tirsojrp
Regards
Bob
Tnx Bob and danardf for your help and care!
CLTedu
