Unable to reach 3CX Updates server.
peter osazuwa
Has anyone come across this message "Unable to reach 3CX Updates server. Check your internet connection and try again"
I can confirm no internet connection issues on our end and no outgoing connection block from a network viewpoint, as least non that we can see...
Cheers,
Peter
What version of 3CX are you running ?
At at guess, you are running V16, you need to upgrade to V18
@peter osazuwa
Can you provide a bit more info on this:
1. Where is the PBX hosted
2. What exact OS is the PBX hosted on
3. What exact version of v18. check in "Dashboard >> Information >> Version"
Thanks @ChrisC_3CX
Hosted on-premise
Ubuntu
Version Number: 18.0 (Build 314)
Additional info:
Our 3CX works with Farsouth Comma iTA devices, in case it helps!
Hosted on-premise
Ubuntu
In that case I strongly recommend you migrate this instance to a 3CX Supported OS. Specifically, Debian 10 if you're opt for staying on Linux. Provided you'll keep this instance on-premise, you will have to use the 3CX ISO to deploy which can be found here along with an installation guide: https://www.3cx.com/docs/manual/installing-debian-linux-pbx/
You should be able to take a backup from the current instance so that you can use it to restore to your new.
Hi @ChrisC_3CX , I gave you the incorrect OS name. it runs on Debian 10.
# Dynamic resolv.conf(5) file for glibc resolver(3) generated by resolvconf(8)
# DO NOT EDIT THIS FILE BY HAND -- YOUR CHANGES WILL BE OVERWRITTEN
nameserver 8.8.8.8
nameserver 8.8.4.4
--2022-04-05 14:04:57-- https://activate.3cx.com/
Resolving activate.3cx.com (activate.3cx.com)... 104.18.15.54, 104.18.14.54, 2606:4700::6812:f36, ...
Connecting to activate.3cx.com (activate.3cx.com)|104.18.15.54|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: unspecified [text/html]
Saving to: ‘index.html’
index.html [ <=> ] 0 --.-KB/s in 0s
2022-04-05 14:04:57 (0.00 B/s) - ‘index.html’ saved [0]
Ok thank you.
Have you made absolutely any changes to 3CX default templates or created custom ones?
Not as far as I know...
The environment was set up 1 year+ ago and with an upgrade from v16 to v18 early this year, involving FarSouth team as we could not do a direct 3CX auto-update due to the ITA devices' virtual Gateway element that had to be handed by FarSouth team!
I was actually going to suggest that you also maybe reach out to them as I know that they use their own modules and repositories, because it might be a good idea that you upgrade the PBX to v18 U3 too. Have you perhaps already contacted them about this?
Yes, I am contacting them, keep you posted and thanks again.
Reactions: ChrisC_3CX
You're very welcome! Do let us know what happens or if there's anything else we can do to help!
Silent_Guru
