Solved Unable to see Call Recordings
JerN
When a call is recorded they are only visible from the admin console under recordings. Users are unable to retrieve their own recordings in the web client. Under the "Rights" for the extension "Allow downloads of call recordings" is enabled. Is there additional configuration that needs to be done to enable end user access or is this feature broken?
Reactions: sv9080w3u02
This is the option you are looking for:
Perfect, that was exactly what I was missing. Thank you.
